09.04.2007, 10:17 PM
sweet MOTHER you have that HV system geared way higher than it should be!
i had a 4400 system with a 6.5 rotor for over a year in my maxx, geared with a 70t spur and 13 tooth pinion, with dual 7 cell packs. temps were in the 120's for the motor and esc, and the batts were at around 100 degrees. if i went up to a 15t pinion with the 70t spur, everything shot up about 15-20 degrees.
you have an enormous gear ratio difference between your maxx and your revo. your maxx is set up for a hv system. your revo is geared to thermal. in no time.
