lutach
lutach's Avatar
09.05.2007, 12:15 PM
Today I drove the truck and it was a good run. I ran it just over 7 minutes with my other 2200mAh, 11.1V packs in parallel, MGM TMM 160-3s and the Aveox 1412/1y. The MGM didn't get warm at all and the lipos were the same way (Impressive), but the 1412 was a bit hot, not too hot because I could keep my finger on it for over 10 seconds. The real story here are this lipos. This tiny packs deliver some serious power. After the run I put them on the charger and it showed 11.64V and I only put 1806mAh back in them. The only problem is they are only available in 2200Mah sizes. The factory told me they are working on a larger capacity. The graph from the DPR-II-150 shows a max AMPs of 164.34A, but there were a few over 100A+ bursts. The pack didn't get warm at all. The MGM has to be the smoothest controller so far from all the controllers I've been using on this truck. I only wish my Quark 125B didn't burn. I will continue tomorrow, but with the MM and same lipos.
Name:	Mr. C's MBX5T, MGM TMM 16016-3s, Aveox 1412 1y, 2 2200mAh 11.1V (4400mAh).jpg
