skellyo
skellyo's Avatar
09.05.2007, 04:18 PM
Originally Posted by rcjmaxx View Post
You mention "in terms of holding voltage under load" is this an issue with the Maxamps cells? Or just there 5000s in general? Are there brands that "hold" better than others?
I wouldn't say it's an issue, just that the Flightpower cells are probably rated a bit more conservatively than the Maxamps. This is more of a concern with Maxamps 4000-5000's typically used in 10th scale or 8th scale conversions. The 6000's and 8000's will do a better job of holding the voltage higher under a large load, but with that you get added weight and cost. IMO, it's all up to how much performance you're willing to pay for.
