09.07.2007, 12:35 PM
- Vehicle type: buggy 1:8 (4wd)
- weight in pounds: 8.82 lbs
- Drive style: constant full speed bashing (actually more racing)
- Top speed in mph (approximate): 42 mph
- Battery capacity in Ah: 2300mAh (10 cells A123 -> 33V)
- Runtime in minutes: 13 minutes
- Peak current draw: 44A
I think you should add cellcount (voltage) or better watt hours of the battery pack. My former 4 cell setup (14,8V) with 4800mAh gave me nearly the same runtime. Energy onboard (Watt/hours) were almost equal to my 10s setup.
good luck with this interesting project ... so many variables to consider to get a good estimate.
