09.07.2007, 09:39 PM
Honestly, the MM should be easily capable of 4s since it is rated for 12 cells, which is VERY close in voltage (both right-off-the-charger and nominal). There's even a 4s LVC setting. However, I've always thought 5s was too much to expect, and still don't think it should be used in larger vehicles even though it could technically work.
