Finnster
KillaHurtz
Finnster's Avatar
09.10.2007, 02:52 PM
Originally Posted by miniGranis View Post
Since you know alot of the TrueRC packs..
Would the TrueRC 8Ah 10C be ok in a E-Revo with a 9XL ?
My FD 3700 mAh 20C pack does not deliver enough juice for the 9XL, it moves like an original E-Maxx with the FD pack :-( but with my Maxamps 8Ah packs it flies..
Can I expect the TrueRC 8Ah 10C packs to deliver the same power as my Maxamps 8Ah packs ?
I have a 4s2p 10C 8K pack that was a 5S pack until I tore it down as it was too much power w/ my 8XL.
They are very good batts, and generally underated. I was pulling over 3.5V/cell @ 120A. Several other here have had simular if not slighty higher #'s (mine are a year old.) They have been very durable and never get too warm (105F usually)
For the price they are really hard to beat. IMO if you are consistantly pulling more current than that, you are most likely getting a hot motor as well and should think about a higher voltage setup instead.
Will it be the same as a MA 8K pack? The #'s i've seen are close, but I don't have a MA pack to directly compare to. I don't think it would be too far behind. It is certainly up to the job and I really like the pack I have, however I liked the 4S 6400 15C TrueRC pack a little better. I would buy either again, esp for $150ish.
How much better is the 15C 8K pack, and how close to a MA pack? That's what I want to know, but if it tracks like their other batts, it should be really good.
