Originally Posted by offroader
Thanks for the info on clearing up the mod 1 with 32p pinions who would carry the upgrade kits for emaxx conversion from 32p to mod 1? Do they sell a mod 1 pinion gear that replace the stock 32p pinions on the emaxx.
http://www.rc-monster.com/gears.php
They have all the different flavours in the RCM shop- MOD1 1/8 bore & MOD1 5mm bore, plus 32pitch 1/8 bore & 32pitch 5mm bore. You can work out the equivalent sizes using the gear calculator:
http://www.scriptasylum.com/rc_speed/_gear_calc.html
For example an 18tooth 32pitch pinion is equal to a 14 tooth Mod1 gear.
