Originally Posted by SpEEdyBL
A lot of sensorless motors that people have been using lately are running hot not because they can't handle the load, but because they are bad motors in general and have poor efficiency. Thus, the instinct is to buy a bigger motor to compensate. The neus are very efficient so you shouldn't have an issue. Frankly, they are very similar in design compared to the novak motors, but Novak is one step ahead of neu and uses sintered rotors verses the bonded segmented rotor that neu uses (that novak used to use). If you want save money, you could also get a novak velociti. These motors are so efficient, all you have to do is chose your wind for power instead of the size of the motor. You can go all the way down to 3.5 turns with them and granted it will do 35 mph and not overheat. Now, if you could fit a feigao rotor (which is sintered) into a neu can, that would result in ultimate power and efficiency.
Not to be a prick
But there is no way in crap that a novak is nicer then a NEU...... I have ran the novak 13.5, and I blew it in half racing it, yess wierd and doesnt happen much, but there motors are built with cheap screws, and the can is cheap alu
So I bought a Team Orion (the new vortex line) 10.5, and the screws and the can is MUCH better quality, and it even has a cool little internal fan, and it has a sintered rotor
NEU it is, I wont do a novak, or any sensored bl set up, I dont think it would run nearely as well as a sensorless NEU, and MM combo
Just IMO though
