MetalMan
MetalMan's Avatar
09.12.2007, 01:08 AM
This motor is going in my Savage, and I had problems when using 33volts and a Feigao 12XL with melting the Kyosho plastic spur gears just from the sheer power, so I need to use steel spur gears. If I knew that the SDP-SI gears would last under that much stress (3000+watts and steel spur), I would buy a couple in a heartbeat.
