09.12.2007, 07:55 PM
Cheap: feigao/wanderer 8xl with a mamba max esc. Will need to disable the mm bec and use an external bec or receiver pack to power servos. Run your lipos in series to get 4s and gear for around 40mph. Will be much more fun
Not so cheap: use an mgm compro esc with a neu motor of around 1800-200kv, a 1512 size will be fine. The compro had a switching bec so an external is not necessary. Wire lipos for 4s and gear for 40mph
With either setup a upgrade slipper clutch will be necessary, strope seeems to be the bes, I just modify mine to use the revo slipper. Not sure how handy you are, as that requires a drill press and good eye!!
Either setup will run very well and be very powerful.
You can use a noval 6500 hv system as well, it is much tamer than the above but can use the stock pinion and has gearing instructions to work well in the emaxx. It will be much more user freindly and many people like the novak setup.
