VintageMA
VintageMA's Avatar
09.12.2007, 10:48 PM
Just thought I would share some updated pictures of my CRT.5. The conversion is almost done after some tweaking.
Decided to run with my MaxAmps 3S 5000mAh in addition to the 4s A123 cells. The 5000mAh pack is just a great fit for the buggy.
Had a problem with the kingpin screws - they are not Locktited! Had one fully back out and got lost in the field - really glad that Ofna included an extra screw pack (that's a really nice touch)! When I went to replace that one I saw that two of the other three were almost completely backed out as well. I was actually surprised to see that the steering arms have metal inserts for the kingpin screws to go into (another nice touch) as I just assumed the screws were going into the composite plastic. They are all locktited now for sure.
Also - went with the 17T pinion and temps are all in check right now.
Filled the diffs with 7/7/5 as the front end was really pulling up and ballooning the front tires something fierce with 3k in the center.
Was getting some pretty bad glitching, so went with Cemtery Gates' ferrite ring solution in this thread http://www.rc-monster.com/tempforum/...ighlight=crt.5. Seems to be helping a lot.
Just got a React at a pretty good price off of Ebay, so that will be installed sometime next week. (Radio, 2 transceivers, 2 temp probes, 1 voltage probe, 1 speed probe all for $300)
ID:	3222   Click image for larger version
“Everyone has a right to be stupid; some people just abuse the privilege.”
