Eccentric
09.13.2007, 01:51 PM
If you like the low profile look then the RC Solutions cage isn't for you. It' requires the body to be mounted higher. I wouldn't get a cage again. It's a pain to do even simple things now. It's heavy I had to repackage every thing to get it to work. Yes it's strong I can stand on it. It's just not worth it. If I was to do it over again I would use a Proline Desert rat body and glue and rivet AL washers to the post mount holes to help with pushing though.
Sorry these are a little out of focus. After a few times running it will look like this.
It's hard to tell but I was trying to show how the right side is bent from a hard landing.
