09.16.2007, 04:36 PM
Originally Posted by A4DTM View Post
how many of the caps are needed for the quark mod?
There isnt a specific number required, its more dependant on the type/size of cap. However, if using the kind of caps Im getting rid off, then 4-6 is a good number- maybe 2-4 if you use higher uf value ones like 1800-2700uf. Most important thing is that you use ones rated for the voltage you use+ a bit of head room, 105*c, low esr caps.
