VintageMA
VintageMA's Avatar
09.18.2007, 10:53 PM
I had very good luck with the MIP diffs. Never had a stripped spur of pinion in either the front or rear diffs. Make sure you shim the diffs - I remember using two or three shims on the gear side of the diff for a good mesh.
I ran the buggy with a Mamba 6800 on 3s with no problems.
This is what I have learned over the years regarding ball diffs.
Tightening and loosening - you tighten the screw until it stops with "normal" pressure - don't try to crank it down hard. Then you back out the screw 1/2 turn (usually more like 1/4 turn that 1/2 turn for high power BL)
The rule of thumb that I had read about on other forums was this - if you take two small screwdrivers and stick one across each outdrive to hold the outdrives in place you should just be able to turn the diff gear with you hands, but it should be very hard to do.
You have to think of the ball diff as providing the same "slipping" function as the slipper gears do on our larger MTs.
Also - it is important to break-in ball diffs. Go to the xray website here: http://www.teamxray.com/teamxray/sho...p?file_id=2438. Read through the instructions on breaking-in the ball diff - it is very important you follow this for any ball diff in order to achieve the highest performance.
“Everyone has a right to be stupid; some people just abuse the privilege.”
