Mailman
09.19.2007, 07:55 AM
If you are staying with an 1:18 I would HIGHLY recommend the Vendetta ST. It is a little bigger and a little heavier than the 18T or the M18t but that really helps in the off road handling. It needs a couple hopups like ball diffs and universals, but after that you don't need anything else. It uses 12mm hex so you can put standard touring tires on it and the gears are completely sealed. It also uses a standard size servo which means you won't be stripping any gears on it as well. I have had pretty much every 1:18 in the last couple years and the Vendetta ST is the only one I have decided to keep - it's that good.
