TexasSP
Something, anything, nothing
TexasSP's Avatar
09.20.2007, 10:32 AM
you could get the 65t steel and that would be very strong.
Stay away from steel spur gears. It is best to keep the spur gear plastic as it is an easy and inexpensive weak point to replace. Going with a steel spur gear moves the weakest point to the transmission, which is much more time consuming to repair and most of the time more expensive.
www.cubicle101.com
