09.20.2007, 11:56 AM
I like to look at it, like camshafts in real engines. As you drop winds its like going up in duration, so while most specs are the same it raises the torque peak a bit. The added winds don't really add torque, if anything the added resistence will drop torque a bit. The reason for more winds, is to move the torque lower and the added wires will help disapate heat
