bluonyx
09.20.2007, 11:45 PM
Originally Posted by ClodMaxx View Post
your first pic is of the steering post holders. the antenna holder isn't worth a darn, as i couldn't find a single hole anywhere that it would fit in...so i had to buy a separate antenna mount.
make sure you use something like weatherstripping on the battery tray slots, as there are some sharp edges in there that will really chew your batteries up.
yeah, I couldn't find a hole to use the antenna holder so I just drilled out the front center hole a little and fit the tube there and perfect! Works for me. I was also thinking about the battery trays, they do seem a little sharp on some edges. I was going to use a double layer of toolbox liner to cushion the tray and give it a little grip too. This stuff:
