09.21.2007, 03:09 AM
jhautz,
I don't have an eagletree, but I can say that I'm running Neu 5S 4100mAh 30C packs. Voltage drop should not be a problem, unless the packs aren't as good as Neu claims.
The temp on my esc during programming gets to over 130*F. It's usually cooler than that when I'm running it.
This is my third Compro and all three gave me trouble. I'm not crazy about them, but they are the most robust that you can get right now.
I would disable the low voltage cut off, but that also disables the over current protection too. I'm running my 22418 in a 7.5lb buggy that I've been drag racing with a Neu 1515/1.5d. What do you think are the chances that I'd fry the controller?
