09.21.2007, 12:42 PM
Another option if you dont mind running with no LVC is you could run in NiMH mode and you would still have your overcurrent safety. But in reality.... If you over current the 22418 I think you will be breaking other things in the drivetrain. 4100mah 30C/50C lipos are only good for 205 Amps burst anyway. So you would toast the lipos beofre the MGM.
I think you are safe. The 22418 is for sure killing a fly w/ a sledgehammer in any normal application. I can pound the heck out of my 16018 and 16024 never have hit the current limit as far as I know. Besides that the 224 is supposed to be constant, burst would be even higher but I'm not sure what it is.
How are the 30C lipos? I was considering getting a pack to test, but in all honesty, my 20c and 25c packs are holding voltage just fine. Its the MGM that has the problem IMO.
Have you seen the cutting out on any of your other MGMs? Just curious cuz Ive seen it on both of mine.
to make it...
or break it...
Silent...But Deadly
