mkrusedc
NeuMaxx
mkrusedc's Avatar
09.23.2007, 11:52 AM
That is an excellent result, those temps are brilliant. As for the shock screws, it might be worth getting one long screw that goes all the way through and holds both shocks to the tower, then use a nyloc nut on the other end to hold it in place.
{noob ducks bullet}
I am using only the coil over PowerStrokes. I was thinking of using the same idea but just for 1 shock. I have 3.3 shafts, so if I don't have enough clearence to do this I may upgrade to CVDs.
