09.23.2007, 04:21 PM
I think I read somewhere that on the throttle graph thing you pull down the curve so there is less power at low rpms, but then it increases rapidly once you hit 1/2 throttle or so- that seems to help with normal MM/feigao setups I believe. Gearing down a little will also help yeah.
