Thread: Battery dead?
09.23.2007, 07:00 PM
A little off-topic here, but just because your charger says it's putting more than the battery capacity back in does not mean it is actually doing that. When the battery starts to get warm towards the end of the charge, that heat is wasted power. So, the last few hundred mAh is probably gone as heat and you are actually getting close to the battery capacity put back in...
