MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
09.23.2007, 08:54 PM
lst and aftershock are similar lst2 seems to have a lot of differences. The 2 speed setup on the aftershock doesn't seem to work until it is upgraded to the lst2 stuff. The A arms of the aftershock break if you look at them wrong. And that's the main issues I can think of. Since you won't be needing the tranny your biggest issue will be the A arms. The easy fix for those is a set of rpm arms or an lst2 chop shop.
