09.23.2007, 09:09 PM
I just thought I would add this. It might have already been stated. To load the PSU I just plugged in an old CD drive. Worked really well. I already had a 12v power source but wanted a second one and I discovered the PSU worked a lot better then my dedicated 12v power source. I no longer got false peaks when charging.
And it does depend on the PSU as to whether you will need to load the 5v or 3.3v line. from experience I have found I have only had to put load on the 5v line. But that was on 3 very similar psu.
