Thread: Idlers??
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
07.27.2005, 06:30 PM
Can you push the bearing all the way through? Can you get a bearing in either side? It does look a bit rough on the inside, actually, but I see a slight ring in the middle, which should locate the bearings. The bearings are a tight fit, due to the hardening process. I have made an adjustment on the next batch to compensate for this.
