MetalMan
MetalMan's Avatar
09.25.2007, 12:21 PM
Glitching shouldn't b an issue with 2.4ghz, but here's something you might want to strongly consider: swap the positions of the MM and receiver. Generally you don't want the receiver close to the motor like that, and if it's mounted to the same plate as the motor, then that could be the problem.
