09.25.2007, 04:40 PM
Code: RW3200-11 RW 32 DP Pinion 11 teeth 1 @ 2.95 = 2.95
Code: RW3200-18 RW 32 DP Pinion 18 teeth 1 @ 2.95 = 2.95
Code: RW3200-19 RW 32 DP Pinion 19 teeth 1 @ 2.95 = 2.95
Code: 4470 Traxxas Spur Gear 70T 1 @ 2.29 = 2.29
Shipping: £ 2.00
Total: £ 13.14
Time for some experimenting, I want to get this gear ratio nailed. I also locked the tranny into second gear & removed the 1st gear RCM idler- suprizingly heavy for such a small part. If I really wanted to I could just order the single speed cover plate since I have the coupler & a million spare screws, but.... bah. Had an interesting thought too; if I decide the HvMaxx is no-longer enough power/speed and get the new Novak system or something else, could I use the HvMaxx in a BL boat- dont see any reason why not?
