09.25.2007, 09:34 PM
http://www.greathobbies.com/producti...d_id=EFLM4060A
OR
http://www.greathobbies.com/producti...d_id=EFLM4046A
Those are 50mm cans, and the Power 60 does 1200 watts continuous. It weights the same as an XL motor. 380 grams You can also take the shaft out, and make a custom one, or whatever.
Thanks for the links ZPB (can I call you buggie?)
The 46 size 670 kv looks interesting, The lower kv would let me put larger tires back on it and have more torque for startup. Do you think that the quark 65 would be ablee to handle that motor? Plus I would need to step up to better batteries, I have a pair of 20c 5000 2s lipos to run. And my motor mount would have to be remade to accomodate the larger can size. I will see about finding one of these motors and change up my setup.
