09.26.2007, 09:46 PM
Is there any reason that I could not remove the red wire from the rec plug instead of the black jumper. Only reson is the esc is not mine and I want to test it on 6s. Do not want to remove the shrink cause that would be obvious.
Will it run well on 6s? I would like to try my 15l feigao on 6s in my emaxx. It is light and 2wd and the batts can handle 80+ amps continuous. Will it be ok? And should I program it for forward brake only, or can I leave reverse? Sorry for the questios, just don't want to smoke it
