Thread: MM capacitors
MM capacitors
MM capacitors - 09.27.2007, 05:53 PM
Firstly I really really really really really SUCK at soldering...
I have 3 MM - On two the caps tops look a little crunched the silver bit is a tad dented - If you saw me drive at the RCM bash you'd know why!
Any ideas that doesn't involve fine soldering work that I can fix or is it send them all back - As they are the "old" variant I'd rather like to keep them - Though one is getting so beat up (leads cut to shreds, switch broken off at board and 4mm connectors crushed) it could do with freshening up!
Does anyone "make/sell" suitable easy connectable cap banks and do I need to worry.
Thanks
