09.29.2007, 01:47 AM
Pesonally the s can feigaos run hot, does not really matter what gearing or how light the vehicle is. I have a 12s in a pede and it runs great, but always around 170f. Never loses power or glitches and the MM stays around 135f and batts at 100f. I would suggest the 10l on 4s lipo. I have a LS10 which is bigger than the crt.5 and it loves the 4s setup (4000 maxamps 4s and MM w/UBec) I have it geared with a 14t pinion (54 spur) and it never gets above 135, even after 30mins. I have a fan on the MM and some holes in the body so the MM rarely beats 115f. Sooooo much power and sooooo smooth. Much beter than the 10l 3s combo I had in my Crt.5. Runs cooler and is just better all around. I am slowly converting all of my toys to 4s+. The higher voltage systems just work better IMO.
