09.29.2007, 11:56 AM
Does it ever cog on startup? If it cogs bad even once and you pull much throttle, that can get it hot.
Try running it outside where it can run free and see what happens.
EDIT: ok.. I see you have the 1.5d not the 1.5y.... (please list the kv)
That may be the problem. You need to gear it down to about 10/46. 3200kv is a very hot motor so you are overgeared pretty bad right now for anything but speed runs.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
