Thread: motor temps
Batfish
Batfish's Avatar
07.29.2005, 03:35 PM
I used to run the Lehner basix xl4200 in my XXX-T MF, geared 19/86.
One thing to remember is that everyone is a little different when it comes to the 'touch' test for heat. You're much better off getting a low-cost IR temperature gauge for more accurate (and less-blistering) readings. OFNA, Duratrax, and a few other companies make these deviced. You should check with Mike and see if he can get one for you.
When I first ran my XXX-T with the xl4200, I had it geared 15/86 and the motor topped out at 190F, which was too warm for my liking, and burning to the touch. Once I geared to 19/86, the motor topped out at 165F, which is much more acceptable, but felt no cooler to the touch than 190F. Either one would burn my finger red in less than 3 seconds.
When the temps get that high, it's hard to differentiate between another 10 or 20 degrees.
I always strive to keep the motor temps below 160F. Most posts you will find about maximum temps will state that the motor innards will start to fail at 220F.
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
