Thread: my UE SuperMaxx
10.01.2007, 11:51 AM
You can try lowering the timing to lowest, may help with the temps. I would put a small fan on the MM if I were you, it helps alot with the temps. The little novak fans work well, just space it off the heatsink about 1/4" for better flow. This will most likely drop temps about 15-20f. If you want a better fan-less solution send your MM to artur(griffinru) to do his stage 1 mod. It will run soooo much cooler than stock. Check my threads for more info, it is under modded mamba max testing.
