Originally Posted by Mallanaga
yeah... what he said. do you use a balancer when you charge them?
that battery actually has 4 cells in it. 2 in series, and each of those 2 sets in parallel. then... since you're running 2 packs, you have 8 cells in your setup! you need to make sure they're all the same voltage.
how's your charger setup?
I have a Hyperion setup. 1210i charger and LBA10 balancer. This battery didn't have balancer leads. I didn't even think of balancing. There's the problem. The other battery is new and balanced. Like I said "I messed up."
My bad. It ran fine by itself.
