What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
10.02.2007, 11:22 PM
Couldn't you do the opposite and spin the motor while measuring the output voltage? Attach a voltmeter between two leads on the motor with a diode in series and adjust the speed of the motor until the voltmeter reads 1 volt. That should give you the unloaded kV, right?
