10.03.2007, 11:41 PM
For the record, the kv numbers listed in Mike's store is the "loaded" value. I did not like this since who determined what the load was? So, I use unloaded kv values (wherever I can). This lets you enter in an estimated amperage and if the motor resistance is provided, makes for a more accurate "loaded" calculation based on the vehicle, not some fudge factor.
As an aside, the last letter in the motor list dropdown, L or U, denotes if the KV value listed in loaded or unloaded, respectively.
