Mallanaga
10.05.2007, 09:31 AM
you'll still get a full charge with the 5i. it will just take longer. that 5000mah rating is the rate that which it fills the battery up. if you set a charger to 2S 6000mah, it should only take 1 hour to
completely fill your battery (milliamp hours)
with the 5000mah limit on the 5i, it will just take a little over an hour. you're still good to go. not a single problem can arise. you might even get a better charge!
point me in the direction of your for sale ad though... i've been looking for that charger...
nothing in the garage right now... another revo on the way, prolly
