07.31.2005, 09:46 AM
Whenever you are ready, Shadow. Also, I can supply all the mentioned items in this thread(solder,battery bars, wire, battery jigs etc.) if needed(most items are already listed). Make sure you use a good, HOT iron when soldering batteries. The longer the iron is on the battery, the greater thenchances of damaging the cells. I use a Hacco iron(cost $100, but is is the best soldering iron I have ever used-I can tin a cell in about 2 seconds).
