10.07.2007, 08:55 AM
Originally Posted by B15 View Post
I think youre going to have this problem anyway; if that fan can produce 5lbs of thrust, its going to be accelerating at well over 1g. The rear wheels wont be able to decelerate it anywhere near that hard.
Provided power to the fan was cut at the same time the mechanical brakes were applied, that should slow the car down pretty quickly. I would have thought quicker than with a normal motor & gear driven car since there isnt the need to slow any rotating mass of the the motor/transmission down before the brakes kick in. If you had a strong enough brake you could lock up the rear wheels and skid the car to a stop rather quickly I'd have thought- useful for emergency stops...
