MGM compro progranning probs
Finnster
KillaHurtz
Finnster's Avatar
MGM compro progranning probs - 10.08.2007, 05:50 PM
Ok, finally got my HV setup running, but I'm having trouble programming the ESC.
I have a MGM 9032 and a 1515 2y (1100kv). Currently using 10S A123.
I got the end point cal fine, went into programming mode, thought I went all the way thru, but its not saving my changes. Namely I want to do fwd only and lightest brake as I have manual brakes.
Just to note, the tx programming sucks. All other controllers I've had at least beep or flash for the step you are on or the option you've selected. The MGM just does the same 1 beep/2 beeps for everything. Its easy to get lost. WTH are they thinking? Lsatly, still don't have the special cable, and this opto ESC doesn't connect thru the servo cable to the usbcom. PITA. For a $400 esc, you think MGM could have thrown the servo cable in for free...
Anyway, get to end, doing the "enter" to go thru all the steps, get to then end where it stops and doesn't respond, prompting you prog is over and to turn off esc. I turn it back on, and I still have reverse....
