AAngel, if you go with lets say a higher voltage will you still get the speed out of the higher turn motor or will the lower voltage with the smaller turn motors have more power? Can any BL motor take the lower or higher voltages 2S-6S?
Originally Posted by AAngel
Speaking in terms of systems, higher voltage systems will draw less current than a lower voltage system. That is to say that a system based on 5S lipo turning 30,000rpms will draw less current than a 3S system turning 30,000rpms (all other things being equal). The higher voltage system will run much cooler.
I consider the 8XL and 9XL to be 4S motors. If you want to run 5S, I'd go to a 10XL.
