crazyjr
crazyjr's Avatar
10.09.2007, 09:47 PM
Originally Posted by offroader View Post
crazyjr, are you referring to a larger battery about 4000mah? Maybe I can double up my other Lipo in parellel I have 2 of these 3S 2100mah. I just thought I would give it another try before trying a new setup since I already have the stuff. What do you think?
Correct, You are pulling a lot of amps getting it moving. I figure close to 40 amp const. and well over 100 amp spikes ( I seen a 120 amp spike with a 9XL on 5S). With your setup, the weak links are battery and gearing. With the stacked 3s, it might work, But i'd go with a 5000 mah Maxamp in two 2s in series, for 4s setup W/external BEC and i'd drop the gearing to at least a 12 pinion and work from there. If you stick with the 5700 Motor
