10.09.2007, 10:27 PM
Ok I see that I am really under geared right now. I'll try the 22 tooth pinion when it comes in. It should make a huge difference over the 16 now.
I shouldn't need a BEC if I'm using a seperate receiver pack correct? The BEC just allows you to pull voltage from the main pack for the receiver and servos thus eliminating the small receiver pack?? One less pack to worry about, I like that.
Where are you finding the 4S 5000 for $125? Maxamps is almost $200 for that pack.
Also, what's the voltage limit for the 9XL? I know the MM is only capable of 4S. Just curious.
Mine:
2007 Grizzly 700 EPS EFI
Sons:
BL E-Maxx
4S MA 4000 Lipo/MM ESC
Feigao 9XL 22/54 gearing
Gmaxx single speed
Brushless Revo under construction
