08.01.2005, 06:56 PM
Yes, the white spacers are for the uper arms. I use the stock black clips(easier) on mine, though. Also, the RDLogics cvds will work, but you have to turn the pillow balls in as far as you can(without binding/limiting steering/suspension movement). You will have to mess with the turnbuckle length once you get it all set up.
