FG101C
10.13.2007, 09:27 PM
After two days at the track on some really loose stuff, the CRT.5 is hooking very well. If the track had been watered down it would be amazing.
The setup that is working for me is as follows.
Front Shocks: 1 hole pistons, 60wt. oil, medium springs. Ride height level, tower position #10 hole, lower arm inner hole.
Front end: 2 deg. toe out, -2 deg. camber, caster 24. Ackerman #1, upper arm mount #1.
Rear shocks: 2 small hole pistons, 35wt. oil, medium springs. Ride height slightly above level, tower position #10 hole, lower arm inner hole.
Rear end: 3 deg. toe in, -2 deg. camber, 3 degree anti-squat, turnbuckle in c-hub hole #3 and tower hole #2
Wing position: F/2, R/1
Diffs: 3k/3k/1k
Proline Crowdpleaser body
Feigao 7l, 2s 5000mah maxamps lipo, Mamba Max, Spektrum micro pro reciever, Hitec hs-5245mg servo.
Total weight ready to run 4lbs. 11oz.
Hope this helps.
