10.15.2007, 11:57 AM
There are actually a lot more spur gear options than that. They range from a 67t spur to a 54t spur.
http://www3.towerhobbies.com/cgi-bin...gear&search=Go
I'll keep on looking for the idler and main shaft pinion gear counts. I'll probably just end up emailing Associated...
Yeah, I kinda figured there were more spur options, but it's funny that they list the tooth count and pitch for some gears and not others. I suppose if you know the EXACT tranny ratio, I could work backwards to figure out the pinion. And speaking of that, I really don't need the idler gear tooth count since it doesn't do anything but reverse rotational direction.
