Finnster
KillaHurtz
Finnster's Avatar
10.18.2007, 08:58 AM
I've the finned version and realy don't fit.
I've e-mail Mike and he can make one to fit.
Hmm that's strange, mine is finned and works well. What pinion?
One thing I did was have all the bolts in loose (rear support and motor) set the gear mesh, then tighten everything.
Depending on how you twist the motor it may not fit correctly if you try to add brace in afterwards.
