sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
10.18.2007, 01:49 PM
I personally do not like the 9920 as much as the MM but the 9920 can handle 6s so it depeds on your future battery choices.
Yeah, and that's exactly my problem....I'd rather go higher voltage/lower Kv than the other way around. The 4S upper limit of the MM is what has held me back there. The higher voltage makes such a difference in the amp load put on the packs, so I could get away with cheaper (trueRC) packs because I might not need a 20C pack to to the job if I end up running 6S.
Yeah. 11XL on 6S. POW, right in the diffs!
Sleeb
